Grinding 3rd...
Grinding 3rd...
I'm grinding into 3rd during quick, high rpm shifts. Now it's always been a bit more difficult to get into 3rd, I used to have to hold it pushed aginst the gear for a half a second or so. Now it grinds for only a second, is this the syncros going out, or something more serious? Also, I have the 6 speed with the hurst emblem on top, what parts to I want to add to the shifter/stick? Thanks..
Re: Grinding 3rd...
If it only happens when your slamming it into gear I would wager to say its the synchro going bad. I had the same thing happen to my car with second gear. It would grind into second for me however at any RPM, just as long as I was slamming it into gear. Turned out my synchro was bad. I don't know what you mean by difficult to get into third. Third gear is a bit rough sometimes and I'm sure that almost all the M6 guys on the board have missed it more than a few times. I know that the later model M6s with the Getrag transmissions had problems with popping out of gear, if that's what you mean.
Re: Grinding 3rd...
It's going in for a clutch, thanks I'll relay the info, but it does pop out of 4th somethimes. And, which shifter do I have (the stock **** with the hurst emblem)? What do I want to buy to help with quicker shifts? Thanks.
