Why are Clutches more fragile than Brakes?
Old 07-26-2007 | 12:58 PM
Sparetire's Avatar
Originally Posted by Asmodeus
lol I'm a winner!! yay!! I've got mail, I've got mail!! YAY!!!
haha seriously.. the Rube Goldberg comment cracked me up, and definately applies!
It is a pretty cool idea though. I think in conjunction with my idea above it could work pretty well. Imagine having a slotted and drilled flywheel
Old 07-26-2007 | 01:23 PM
Vertigo's Avatar
You can not allow any moisture to get onto the surface of the disk or flywheel. Even hummidity will effect it.
Old 07-26-2007 | 10:58 PM
Sparetire's Avatar
That explains a lot. So we need the Goldberg idea in conjunction with the vents. Brakes dont mind water too much
Now we just need lots of money, time, and boredom.....
Old 07-27-2007 | 08:10 AM
Old SStroker's Avatar
Originally Posted by Sparetire
I am no engineer. I know. I tried mech engineering school and concluded that I would go insane looking at that many excel sread sheets.
IMO, you were wise to switch majors.
Originally Posted by sparetire
More complex but using well developed tech: Use a clutch system similar to what some LSDs use. The clutch is surrounded by heat sensitive fluid. Fluid gets hot, clutch enages, as when slippage happens. This fluid could be used a cooling system, much as some hi-po LSDs on hard core road race apps use diff coolers. It might be perfect for slipper application on the drag strip. Might be hard to do on a street car at cruise though. Some sort of lock-up system at speed might be needed so that it acts normal after you initialy start out.
That's a fairly good description of a lockup torque converter.
Old 07-27-2007 | 08:40 AM
Jon5212's Avatar
I have also wondered this... especially with these high dollar clutches like Tex and Ram. I understand they are built to handle high horsepower... but a clutch only slips when you tell it to until you have full engagement. Unlike brakes which have to slow down a 3500 lb car over a very long time. And then what about automatic transmissions? They have clutch packs in them, albeit there are more than one but each clutch inside does not have much surface area and those are lasting in very high horsepower cars and they slip as well.
Old 07-27-2007 | 10:40 AM
slick1851's Avatar
Some awd guys add Tranmission coolers to there trannys for road racing etc...
Old 07-27-2007 | 12:30 PM
MrDude_1's Avatar
GM has a kit for roadracing the vette..
its basically a pump, a cooler, lines/fittings that fit into the drain and fill holes..
its pretty pricey too.
Old 07-28-2007 | 01:08 AM
GMC_DUDE's Avatar
Believe it or not, that is an old idea. It was used on Hudsons many years ago (early 1950's I think, maybe older) and was called a wet clutch. Its purpose was to give a softer, more gradual engagement. It was part of their early automatic transmission design which was basically a manual tranny with vacuum servos doing the gear shifting and clutch work. (In those days without high tech electronics, servo control which was affordable to the public had all the finesse of Herman Munster). I'm not sure how well it held up though, maybe someone else knows?
EDIT: Yes I am an old coot.
Old 07-28-2007 | 04:33 AM
DBL_TKE's Avatar
Well I supposed it's not to hard to assume that it didn't work out exactly as planned for as far as I know there's no modern transmission that uses such "technology." Very good design theory though. I like this thread. How exactly does a tranny cooler work for a Manual transmission? I knew they had tranny coolers for auto's but not manuals. Is it air cooled or something?
Old 07-28-2007 | 04:59 AM
DaddySS's Avatar
Another consideration - by my calculations, a 17 inch wheel is rotating at 800 RPM at 60 MPH, vs. a clutch rotating at between 1200 and 3000 RPM when you launch - the heat build up I would think is much faster and with little ventilation as stated above the window for heat damage becomes pretty short.
Old 07-28-2007 | 05:06 AM
DBL_TKE's Avatar
A slotted and drilled flywheel sounds kind of like a good idead, but then you have less surface area. You could also add cooling vanes perhaps?
Old 07-28-2007 | 08:24 AM
  #32
LrngCrv's Avatar
A clutch is designed to not slip at all 99% of the time. A street car's clutch is made to grab and send the power down the drivetrain. Brakes are designed to slip and slow the wheels down by dissipating heat from friction.
Different purposes with similiar basic ideas. If a clutch was worked just like a brake then you would be spinning and losing power instead of transfering power. Pressure needs to be put down to lock it. If brakes lock then you are in trouble. That is why they are made different, last differering times and need more or less heat consideration from what I'd gather.
Kinda like brakes that are locked up would not be getting hot or being worn down, wouldn't be stopping your vehicle either tho...
I guess it is kind of a give or take thing.
Old 07-28-2007 | 10:39 AM
  #33
Sparetire's Avatar
That explains a lot, thanks. I really dont understand the auto tech stuff yet. Good to know.
Old 07-30-2007 | 12:33 PM
  #34
Jon5212's Avatar
But if the clutch is NOT slipping 99% of the time... why do they not last as long as a set of brake pads when you do "slip" the brake pads QUITE a bit more than a clutch. And the flywheel acts as a heat sink as well just like a brake rotor. So it still remains why do these clutches not last as long when they operate almost on the same principles as a brake pad and rotor?
Old 07-30-2007 | 01:06 PM
  #35
MrDude_1's Avatar
umm, read post #32 again.
clutches are not ment to slip. they are ment to grab. when they slip, they wear.. and they're only 1/8" thick.
meanwhile your brakes are MADE to slip, not to grab. when they slip, they dont wear as quickly... and they are over a half inch thick.
material composition and amounts also come into play, its not just heat dissipation.
the only "principles" they both have in common is that they use friction to transfer force.. thats it... ohh and they both rotate. lol.
Old 07-30-2007 | 01:21 PM
  #36
Jon5212's Avatar
^^^ Ok, so why is clutch material only 1/8" thick? Why not put a thicker piece of friction on them? And i know that clutches are not meant to slip, and I know brakes are not meant to grab all the way. It just seems to me that a good performance clutch could be made to last pending all other problems are corrected, IE good master and slave cylinder, good pressure plate all that stuff.
Old 07-30-2007 | 02:08 PM
  #37
MrDude_1's Avatar
because the MATERIAL is diffrent.. once you've slipped that clutch to the point where the material thickness comes into play, it doestn matter.. its going to burn up..
now, if you had a "brakepad like" material that was ment to slip, and adjusted it so it did slip just right, and made the material thicker....
....then you've just re-invented the slipper clutch. the same kind of drag race clutch alot of race cars use.
next, you'll want to put some clutch material and plates together and stack em.. ooh, better yet, lets have these stacks "lock" together with some pins as it goes down the track...... you know.. just like the big drag cars.
Old 07-30-2007 | 02:16 PM
  #38
Jon5212's Avatar
No need to be a smartass, I'm just asking questions. Anyone else care to chime in?
Old 07-30-2007 | 02:46 PM
  #39
MrDude_1's Avatar
wasnt trying to be a smartass.. just pointing out that the logical progression of ideas have already been implemented, you just have to look it up.
like the guy describing the torque converter above... lol.
Old 07-30-2007 | 03:59 PM
  #40
Gary Z's Avatar
Good question. One of the major constraints in clutch design is the rotational inertia of the disc. The disc’s mass and radius need to be kept within limits so the transmission’s synchronizers can work properly and survive. I think that the answer to my original question is closely related to the issue of the disc's rotational inertia but I don't know if it is the biggest factor.
Quick Reply: Why are Clutches more fragile than Brakes?
