Thoughts on Pro 5.0
http://www.installuniversity.com/ins...er_install.htm
This is the boot you have to cut for the 5.0:
If you don't cut it, you WILL get rubber chunks in the shifter. I never cut mine and when I took my 5.0 out to sell it, it had tiny pieces of rubber in it that I had to clean out. You may also consider using some fiber washers between the stick and shifter and cutting your 5.0 stick 1" since the sticks come longer than a short stick like LSS. Also be sure to use red loctite.
If your car is under warranty still, be careful about the the 5.0 shifter since they could void any trans or clutch work because of the aftermarket shifter. When my clutch was having problems, I took out the 5.0 just in case.
Good luck!
