Clutch shot?
Old Jun 28, 2007 | 06:40 PM
Viper's Avatar
Default Clutch shot?
It now shudders in all gears, feels like down on power. If I put it in 6th, it just shudders, rpms move but car does not.
Clutch shot? I'm just asking before pulling the clutch to inspect it. My guess is it is not the rear end.
Old Jun 28, 2007 | 08:27 PM
letsrun97z's Avatar
i knew mine was gone when i was on the freeway and downshifted from 6th to 4th and it just went bwahhh no go lol
Old Jun 28, 2007 | 10:07 PM
Killer_Bluebird's Avatar
Hey I went pass that shop but they where closed. I'll check tommorow to see what their rates are.
Old Jun 29, 2007 | 04:54 AM
vettenuts's Avatar
Sure sounds like it is going out. Mine slipped badly on the dyno on the first few pulls and then eventually held. What was amazing to me was when I pulled it out it looked brand new (stock Z06 clutch). Since removing it, I read the manual about installation and there is an adjustment that is required when the new sotck clutch is installed. I am wondering if this adjustment is also applicable if the clutch is slipping. In the end I went to a Tex X-grip as a replacement and there is no adjustment on the Tex.
Old Jun 29, 2007 | 06:12 AM
Viper's Avatar
Vettenuts
Thanks, if you recall you asked about my clutch a while back, Clutch Masters. Well, i did get 22K out of it, countless autox, 7 20 minute road race sessions and about 50 passes at the drag strip. Can't complain about that!!
I may stay with the FX300 series or jump up to the FX400 clutch, I know you looked at both too. The FX400 has instant engagement and no slipping so may not be good for DD, however it will hold quite well. I drove the RAM 980 (sintered iron) for 10K so it can't be any worse than that. The Tex X is too much cash right now, this will be my 5th clutch (stock, Z06, ram, clutch masters).
Killer Bluebird, a friend is coming by tonight so we can drop the tranny to inspect. He just did 2 last month and says we can have the tranny dropped in one hour.
Old Jun 29, 2007 | 10:05 AM
1hr? I got to see this, when is he comming over? I may drop by to watch. PM you address since I can't remmember how to get there.
Old Jun 29, 2007 | 10:20 PM
letsrun97z's Avatar
very possible with the right tools and tranny jack i had mine in and out with in 2hrs
Old Jun 30, 2007 | 02:29 AM
RGKSR's Avatar
Default Cartek Level 7 Clutch
I just put a Cartek Level 7 in my C5. I love it. No chatter and it feels like stock.
It's rated for 700/700 and uses the stock slave & master.
Bob K.
Old Jul 1, 2007 | 07:38 AM
Viper's Avatar
Turns out clutch is fine, we didn't have to drop the tranny. A bad O2 sensor was causing it to miss so bad under load it felt like a bad clutch. Glad I had a friend drive with me before pulling the tranny.
