having some trouble, need help fast please.
got the new clutch in my car. spec stage 3+ everything went relatively well. got everything buttoned up and went through the gears with the car shut off. everything seemed ok. start the car in nuetral and there is a bad ticking noise. almost sounds like something is broke, and the car wont go into gear while running. shut the car off put it in gear and start it again, the noise went away while the car was in gear, but the with the clutch pedal on the floor the car still rolls forward. is it something to do with the throwout bearing? maybe i need to bleed to system? ANY help would be awesome because i would like to get this thing done by tonight. thanks alot.
You seem to be experiencing creep. Start by bleeding the hydraulics and then see if the issue goes away. What flywheel was used? If stock or a previously used aftermarket unit was it resurfaced? Let me know and we can go from there. You can of course call me to discuss this real-time if you like. Thanks!
i am using a brand new spec billet steel flywheel.
calling would help, what is the number to call? i would like to have this thing done tonight, because tonight is our towns big cruise.
thanks a ton.
thanks a ton.
If you bleed it and the same problem still exists... save the ongoing headache, pull the tranny, put a spacer behind the slave and button it back up. I give it a 99% chance that it'll be just what the doctor ordered.
