[b]need Big Help On My Trans[/b]
hey I Installed A Brand New Ls7 Clutch With Flywheel Clutch My Self And A Buddy. We Put Everything Back And Bleed The New Slave Cylinder. I Broke In The New Clutch, Everything Was Going Good. Intil My Fourth Gear Grindins A Little. I Tried More Many Time To Put It In Fourth. Then It Got Stuck I Played With It To Come Out Of That Gear. And It Grinds In Third And Fourth. I Dont Know If I Need To Bleed The Slave More Or What. Is Going On, Because I Dont Think I Did A Great Job On Bleeding The Slave. Do You Guy's Think Its The Trans Or The Clutch That Needs More Bleeding Or Adjust Ment Need Help With It.......
wrencher
Common problem on stock transmissions to break the slider keys in the 3/4 synchro hub. So yes internal trans, unfourtunetly it's rebuild time for yours.
Read the Manual Trans FAQ thread at the top of this section.
