Balancing a fly wheel
Old Jul 16, 2007 | 03:23 AM
mook99ta's Avatar
Default Balancing a fly wheel
I have read in instructions for the M6 swap from an A4 that you need to balance the flywheel. Do I need to do this or do I get a zero balanced ram flywheel?
Old Jul 16, 2007 | 08:09 AM
brad8266's Avatar
you can take your clutch/flywheel to the machine shop and have it balanced.
Old Jul 20, 2007 | 03:51 AM
mook99ta's Avatar
is this required if I get a ram billet steel flywheel and a ram clutch?
Where in savannah you at brad I am also from savannah but not right now.
Old Jul 21, 2007 | 01:15 AM
meatyshells's Avatar
if you buy a new flywheel, it should come balanced, when i did my conversion i just used a stock replacement flywheel and it worked fine. No viberations
Old Jul 21, 2007 | 09:58 AM
PureWS6's Avatar
I just purchased the LS7 clutch kit with the LS2 flywheel....will balancing be required?
Old Jul 21, 2007 | 10:07 AM
SSDoubleK's Avatar
Wink
In my experience, any clutch flywheel setup you should always get them balanced, the LS7 is for sale all over ebay, and one of the vendors has in big bold print, that they highly advise on getting that clutch balanced before install. I just took my clutch setup out, and got it balanced, 100 percent improvement, smooth engagement, no problems. Get it done its well worth the 40.00 bucks.
Old Jul 21, 2007 | 10:15 AM
Ranger's Avatar
King of the radial tires
Always, always, always have the clutch clutch balanced before installation. If you don't the vibration gremlins will haunt your ride.
Ranger
