clutch help
Old Nov 11, 2002 | 07:54 PM
alws6's Avatar
Default clutch help
just pput in my spec 3 and the peddle feels kinda sponge and engages very low. it has been bled. do i need to do the drill mod and get an adjustable mater cylinder?
Old Nov 11, 2002 | 09:19 PM
991LE's Avatar
Default Re: clutch help
You still have air in there<most likely>. Try reverse bleeding or using a vacuum pump if all else fails.
Old Nov 11, 2002 | 09:56 PM
LOnSLO's Avatar
DO the drill mod. Rebleed the slave and master, and you're good to go. It takes two people to correctly bleed the system, unless you're using a vacuum pump.
