bellhousing and flywheel bolt patterns
Old Nov 21, 2002 | 07:02 AM
pmg's Avatar
pmg
Default bellhousing and flywheel bolt patterns
My understanding is that the LS1 bell housing bolt pattern is the same as the original small block. Is this correct? This means that I can bolt a standard chevy small block bellhousing to the back of the motor?
Is the flywheel bolt pattern on the crank flange the same as the small block with the one-piece rear seal?
I've heard that the distance from the flange to the bellhousing face is different and requires a spacer. Is this true?
I guess what I'm getting at is: If I want to bolt by existing small block can and clutch up to the LS1, all I need is a spacer between the crank and flywheel?
Thanks,
Perry
Old Nov 21, 2002 | 11:23 AM
GeorgeC's Avatar
Default Re: bellhousing and flywheel bolt patterns
The bolt pattern is similar, but not the same. Using a traditional SBC bellhousing, you'd be able to get a total of 5 bolts in (2 on each side, and one on the top left side).
Old Nov 21, 2002 | 11:50 AM
pmg's Avatar
pmg
OK. I can either drill and extra hole in the can, or not worry about it.
I assume that the dowel pin locations are the same then?
Do you happen to know about the crank bolt pattern and length/depth?
