Need help with explanation of additional parts for ls7 clutch
i bought the ls7 clutch kit with the ls2 fly wheel. What other parts do i need? Could y'all explain what the parts are/do?
The car is daily driven, not track visits, little to no street racing, so i dont need some high performing set up.
Thanks.
oh yeah do i need to change a gasket near the drive train? Or any gasket for that matter? My uncle just told me that a gasket has to be changed but he cant remember which one
Thanks.
Location: Your girl's back door giving her the long stroke while you're at work
The only thing I changed was the slave because I went with a RAM big bore slave. I reused the stock bolts aswell, didn't shim anything and also reused the stock bearings. But my car only has 35K on it.
Originally Posted by osvaldo
my car has +80K miles, whats ks1 pilot bearing? T/O bearing?
what do you mean by shimming the slave?
Do i need to replace any gasket?
Simply put you need...
1 GM Slave Cylinder (it will come with the TO Bearing)
1 GM Pilot Bearing or Bushing
You may want...
An 1/8" spacer behind your new slave
A good transmission jack, or you'll be hating the whole install/removal
I've never used new bolts, and I've been through 192k miles and on my 4th clutch.
You may want...
