454/t56
Old Aug 6, 2007 | 09:38 AM
MonsterZ28's Avatar
Default 454/t56
Building a 454 for my gf's 82 z28. Will a T56 bolt up to it without any issues?
Old Aug 6, 2007 | 06:53 PM
MonsterZ28's Avatar
anyone?
Old Aug 6, 2007 | 08:09 PM
ae13291's Avatar
your going to need a differnet bellhousing but the lt1 t56 should probley be better with your application, it will be better fitment
Old Aug 6, 2007 | 10:52 PM
itslow's Avatar
The bellhousing on the LT1 T56 isn't large enough to fit the 168 tooth flywheel the 454 needs. You'll have to use one of the aftermarket bellhousing solutions (McLeod or Weir), or use the aftermarket T56 that can bolt up to the traditional GM bellhousing.
Old Aug 7, 2007 | 12:58 PM
calhoon's Avatar
There is an aftermarket T56 that is made to adapt to the 4bolt bow tie bell and use the original release system. Check out a 1386-000-011 T56.
