Lubricant for solid bronze pilot bushing?
also, dont put any on the trans shaft.. you're bound to touch the clutch some, and if it gets on the splines, it will "scrape" into globs on it.. then be flung into the clutch (once more grease + clutch = bad)
just enough to rub onto the bushing is fine.. technically its soft enough that it is "self lubricating" as said previously.
