What do you think about my T56 gears - need replaced?
I am in the process of rebuilding my T56 and am trying to decide what gears to replace. 1-4 are my main concern. 5th adn 6th are OK. I am thinking 2nd and 4th need replaced, but not sure about 1st and 3rd.
If you guys have an opinion I am all ears.
1st gear: http://i83.imagethrust.com/images/5l.../1st-gear.html
2nd gear: http://i84.imagethrust.com/images/5l.../2nd-gear.html
http://i84.imagethrust.com/images/5l...ge/2nd-gr.html
3rd gear: http://i84.imagethrust.com/images/5l.../img-1614.html
http://i84.imagethrust.com/images/5l.../img-1615.html
4th gear: http://i83.imagethrust.com/images/5l.../img-1617.html
http://i84.imagethrust.com/images/5l.../img-1618.html
Thanks
Thanks
Originally Posted by TheLS1Kid
You might as well replace them all while your in there.
That way EVERYTHING is brand new!
Had I held a new gear in my hand prior to ordering I probably would have just ran a couple of them and saved a few bucks. I ended up replacing all the gears.
Your first and second gear look in pretty good shape as far as I can tell. I'd look at replacing 3rd and the input shaft/4th gear.
I sent this to Amber at Six Speeds Inc, so hopefully she will give her opinion. I am willing to buy all new gears if needed, but these arent cheap. New 1-4 gears would run me $500.
Thanks for the advice guys.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Its the clutch teeth that count on these. As was stated above, the 1st&2nd aren't too bad. I would replace the 3rd and input. What about the drive ODs and reverse driven? 5th and rev driven generally take a spanking.If 5th is damaged, get a new shift fork as well.
Thanks for the help guys, and thanks Amber. I did replace 1-3 gears about 2000 miles ago during my first rebuild. Glad to know that darn draggin clutch didnt mess everything up.
Amber, you will be getting in input shaft order from me soon.
