Stock throwout bearing shim missing?
Formerly 4mulaJoe
I'm told there is a stock GM shim on the throwout bearing. Is it plastic or rubber? I think I am missing it and the rubber piece i see is the seal. That would explain my clutch engaging only 70% and the very top. So is there suppose to be a plastic shim and a under that a rubber seal on the shaft of the slave cyl?
I can shift faster than you.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
You have to take the throwout bearing off the slave cylinder to access the shim.
There are some good pics here:
http://www.installuniversity.com/ins...ch_install.htm
Jason
Jason
Formerly 4mulaJoe
I did. I have it right in front of me. I think the only thing in there is the rubber seal. When I poked at it fluid came out.
