Power shifting, missing 3rd gear & the drill mod
Old Aug 8, 2007 | 08:40 PM
Michael02hawk's Avatar
Default Power shifting, missing 3rd gear & the drill mod
Before my recent install of the new clutch (Textrellia) over my poor stock 2002 setup, I would miss 3rd gear like most, when power shifting. From what all I've read, thats all related to the restriction in the line on the Master.
So when the new clutch was installed, I went ahead and had a new master & slave installed, along with drilling out the restriction.
Anyway, When power shifting, It seems I still run into a problem getting it into 3rd gear.
Anyone else run into this, even with the drill mod?
Old Aug 8, 2007 | 09:34 PM
PureWS6's Avatar
do you still have the stock shifter?
Old Aug 8, 2007 | 09:49 PM
The Trans AM came with the optional Hurst shifter from the factory, that I am still using.
Old Aug 9, 2007 | 05:03 PM
LawHorn's Avatar
There's your problem....... Go to ws6store.com and buy the short stick for around 24 bucks..... I bet that solves your 2-3 shift problems
Old Aug 9, 2007 | 05:53 PM
cjels1's Avatar
haha stock hurst sucks get a short stick asap
Old Aug 9, 2007 | 07:08 PM
I dunno if thats the problem or not, it feels like it did when the stock restriction was in the Master line, just not as often, and only at 6k rpms now.
But, It wouldnt hurt to rules out the stock Hurst shifter ,I have a Pro 5.0 stick on order now - should be here mid next week. I hope thats all it is.
Old Aug 9, 2007 | 10:10 PM
BLK02TA's Avatar
As much as I hate my pro 5.0 I have never missed 2-3.
Old Aug 9, 2007 | 10:18 PM
CaMaRo67RS355's Avatar
how hards the drill mod and what is it and how do ya do it any write up on it search aint working... i have a aftermarket hurst comp shifter and 6inch ws6store short stick but ive missed 3rd...
Old Aug 9, 2007 | 11:09 PM
Sharpe's Avatar
By power shifting, you mean that you're stabing the clutch to the floor without letting up on the throttle, right?
If by "missing" you mean you don't get it in gear, then you need practice. If you mean you're shifting into it just perfectly, but get shut out, then that's another problem unrelated to your shifter.
Old Aug 9, 2007 | 11:10 PM
Sharpe's Avatar
A link to drill mod instructions is in multipley stickys above.
Old Aug 9, 2007 | 11:12 PM
Zero4488's Avatar
Restricted User
Pro 5.0 fixed my problem....
Old Aug 10, 2007 | 12:04 AM
99mongooSS's Avatar
the shortstick solved mine.
Old Aug 10, 2007 | 06:28 AM
Oh! Why do you hate your pro 5???
Old Aug 10, 2007 | 06:32 AM
By powershifting I mean shifting in higher rpms.
I try not to abuse (stab, slip, etc) the clutch.
As for my "missing" - good question!
At 1st, it felt like I was shifting into it perfectly but got shut out - thats why I started this thread.
But by using it more (I've only started getting on it harder this week, since the new clutch was installed) it may be more of a practice/better shifter thing.
It only seems to be a problem at 6k rpms and up, I'll "practice" with it more this weekend, and I have a new pro 5 on order, i'll get it installed next week, and hopefully its not "something more" wrong with my setup. :-)
Thanks all
Old Aug 10, 2007 | 12:59 PM
RealLiveMD's Avatar
You need the drill mod. I've had the car for 6 years and I have only recently been able to shift to 3rd above 5500 rpm after the drill mod.
Old Aug 10, 2007 | 01:09 PM
Yup - that was already done last month with the new clutch, flywheel, master & slave - see 1st post.
Old Aug 10, 2007 | 09:01 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
So your just shifting quickly, or speed shifting rather.
I was going to say.. If you're powershifting and missing, timing and technique is the cure.
But IMO, the factory Hurst is junk. Pro 5.0 with a straight short stick is the only way to roll. I've tried a few others, and this combo is perfect in my eyes.
One thing top remember, as you keep going up in HP, your timing changes completely. Timing, technique, and practice is all you can do.
Old Aug 10, 2007 | 09:43 PM
Sharpe's Avatar
That's not power shifting. That's shifting in higher RPMs.
Well, that's the $64,000 question. Can be anything. Never seen this question answered 100% on here. Happens to me sometimes on rare occasion. Very common problem.
Old Aug 11, 2007 | 02:07 PM
plainred02Z's Avatar
I'm a bit of a manual noob and was having that same problem. I went to my local speed shop ( eastside ) and the guy took my car for a spin. He was able to shift fine at 5800 - 6K ( although you can't granny it in there, you gota shift it like a man ). He told me I gota make sure the clutch is all the way down and wait like a quarter of a second before I shift, so that the hydrolics could catch up. This is with a 100% stock setup.
I took his advise and moved my seat a bit forward so to make sure the clutch pedal goes all the way down, and then instead trying to simultaneously push the clutch and move the shifter, I pushed the clutch 100%, waited a fraction of a second, then banged that ****** in there. Went in like a hot knife threw butter. Might not be the same issue for you but dosn't hurt to try.
Old Aug 11, 2007 | 05:43 PM
nvmy2000ss's Avatar
I think the stock hurst shifter is great, with the addition of a LSS. I have never missed a gear. could be luck I guess.
