Please help with my clutch problems
I really don't understand the hydraulics the way I thought I did. All that it did by me shortening the rod was make it so that when I press the pedal in to disengage the pressure plate the plunger does not go in as far which sends less fluid to the slave. Why does that make the clutch engage earlier and grab better?
Also, I think I should do the drill mod to see if it helps it slip into gear smoother at high rpm's. Will this effect the engagement of the clutch at all or just help it disengage at high rpm's only?
As for the rest of the hydraulic stuff, think about it like an old mechanical linkage setup. If you had it ajusted too far out it wouldn't engage or too far in and it wouldn't disengage. It's the same principle it's just being done by fluid instead of steel. I know that's about as clear as mud but I've had one or three too many to really write something good on the subject.
Hope this helped.
I know it's expensive, but you might want to consider the McLeod M/C.
Mike
Mike
Do a search in this section for posts by me and there is some discussion on it. At the end someone posted a link on how to. Its very informative and should take car of your problems. It will allow you to displace more fluid to completely disengage your clutch allowing much easier shifting.
