Centerforce Clutch problems?
I have a Dual friction clutch made by Centerforce. I have read to stay away from these clutches, but it was to late. Anyway, I am having problems shifting into gears (any gear) when I get into the higher rpms. I am not talking about 6,800rpms, this happens between 3-5k as well! My hydros are new, as well as my flywheel.
Is this one of the bad "traits" of the dual friction? Either way, it is really pissing me off.
Thanks
Thanks
Hello,
Please call our tech line (800) 932-5882. I am Curious to what Hydraulics you are using (Master & Slave)? I am assuming this is a LS1 & T-56 in a 1987 T/A?
Thank you,
Will Baty
Centerforce Clutches
Thank you,
Will Baty
