Strange wear on my clutch after 3800 miles
Old 08-11-2007, 02:10 PM
bowtieman81's Avatar
Default Strange wear on my clutch after 3800 miles
So in the process of my turbo install I am rebuilding the trans and inspecting the clutch. I had a period of clutch dragging problems last fall. It seemd related to the colder weather. Well, I took the clutch apart and this is what I found. The pressure plate side looks darn near perfect, the flywheel does not though. Anybody seen this before? I expected to see both sides showing signs of slipping.
Old 08-11-2007, 03:17 PM
Gary Z's Avatar
I haven’t seen many mid-life clutches so I can’t give you expert advice. But I am not surprised that the two sides have different wear patterns because the flywheel and PP are different material – billet steel and ductile iron. If it was my project, considering the difficulty of replacing a clutch, I would take the opportunity to install a new disc and have the flywheel blanchard ground.
Old 08-11-2007, 05:31 PM
Yellowbrother's Avatar
hey...ish dat an ebay clutch??? i bought one but haven't had a chance to drive it yet....
Old 08-11-2007, 05:37 PM
nvmy2000ss's Avatar
Is that a text? I just sent mine back for the same reason. Everthing worked great but when I pulled the motor to replace it I found the clutch looking like that.
Old 08-12-2007, 10:06 AM
Gary Z's Avatar
I just noticed your McLeod bellhousing plate. Are you aware that the plate makes the McLeod deeper than the stock GM bell? If you didn't add a shim equal to the plate thickness then your clutch might not fully disengage.
Old 08-13-2007, 09:08 AM
Yes it is a textralia
Gary, where did you find out that a shim was needed? When I asked that I was told it would work fine on an LS1, no shims needed.
Old 08-14-2007, 09:18 AM
Gary Z's Avatar
The Textralia doesn't need a shim if you have a stock bellhousing. The McLeod modular bell is very near to stock depth (5.5 inches) without the plate. With the plate, the McLeod is deeper than the original bell.
Quick Reply: Strange wear on my clutch after 3800 miles
