Problem with Trans/Clutch help!!
Old Aug 22, 2007 | 10:34 PM
DJB's Avatar
DJB
12 Second club
Default Problem with Trans/Clutch help!!
I put my new engine in and put my trans and clutch back in and bleed it. I put the crank pulley back on and I am trying to turn it the extra 140 degrees. When I put the trans in 4th or 6th gear the crank starts to turn. Could someone tell what could be wrong to make the crank still turn?
Old Aug 24, 2007 | 07:59 AM
wrencher's Avatar
wrencher
The clutch must not be holding.
Does the clutch pedal feel normal? Not an adjustable master is it?
