Spec and Ram shims for slave...same thickness?
Old Aug 28, 2007 | 05:30 PM
Screamin_Z's Avatar
Question Spec and Ram shims for slave...same thickness?
I just took out my Spec 3 out and put in a Ram Twin Disc. I'm gonna have to pull my tranny back out again and put a shim behind the slave because the clutch is engaging right off the floor and it's a lil stiff to shift.
now, my question is...is the Spec shim the same thickness as the Ram shim? if it is I can just reuse my old one. i ordered a shim with the clutch but the sponsor I ordered it from forgot to throw it in SO...I want to see if I can reuse my old shim.
Old Aug 29, 2007 | 02:18 AM
SLP4CamaroSS's Avatar
ttt... im looking for a spec3 shim lol
Old Aug 29, 2007 | 02:22 AM
Screamin_Z's Avatar
since ur in OK and I'm in KS...if it's not the same thickness (which I'll find out tomorrow when Ram is open) then I'll just send it to u no cost.
Old Aug 29, 2007 | 02:44 AM
i appricate that hey did u use the stock flywheel?
Old Aug 29, 2007 | 08:23 AM
VIPRETR2's Avatar
The Ram shim I bought was .150 thickness. RAM-598
Old Aug 29, 2007 | 12:08 PM
Screamin_Z's Avatar
thanks
Old Aug 29, 2007 | 12:36 PM
how thick is the spec shim?
Old Aug 29, 2007 | 01:42 PM
Screamin_Z's Avatar
I'll find out. it's over in the garage but I'll stop by there tomorrow and take it to work and mic it.
Old Aug 29, 2007 | 03:02 PM
alrighty appriate it again
