Drill Mod Poll
How long does this drill mod take to do? Should it be drilled 1/8" or even narrower, like 1/10"?
Search for "drill mod" on here and you should get plenty of info on it. I know there is a detailed install article on installuniversity.com.
thats what mine does, i did the drill mod and it helped alittle but i think the only for sure fix is a new clutch /pp/flywheel
check under the Install Documents > Transmission
There will be some differences because you are a C5 but there's enough photos and info to get you everything you need with one exception; I highly recommend a GM clutch line removal tool. They are $5 and make a hard job simple when it comes to dis-engaging the clutch hydraulic line from the slave cylinder in the bell housing.
