Clutch swap/trans removal sticky!!!
#61
I've read through this thread a couple of times and the only thing I would want to add is the importance of using the aforementioned clutch hydraulic line tool (for the LSx slave).
While doing the drill modification I fiddled with the connector with screw drivers for about twenty minutes. I couldn't get lucky with them so after a trip to the autoparts store and buying the removal tool for just a few dollars, I had the line disconnected in one minute. I would add that to the list of necessary tools.
#62
Trying to reinstall the back half of the transmission onto the bell housing right now, after installing a remote clutch bleeder. For some reason the dowel pins are not lining up. If I line up a dowel pin on one side, the other will be offset by a quarter of an inch, and vice versa. Any ideas?
#64
It is a pain in the *** if you are doing it by yourself. I got my by myself and it was my first time. I also saved myself over $400 bucks pulling the trans, replacing the clutch and then reinstalling the trans. It was worth it in my opinion to do the work myself, and next time I'm sure it will go smoother!
#65
Yea it's definitely possible. I just replaced my clutch a couple weeks ago with just jackstands. Just make sure you get it decently high, I barely had enough room to get the trans to slide out from under my exhaust. As far as time, me and my buddy were complete noobs and it took us two seperate days to finish. Probably a total of 10 hours of work. Getting that damn bell housing loose and bleeding the hydraulics took FOREVER lol
#67
You don't "have to". I didn't. 2 weeks later I'm doing it now though. Big ****** mistake
Also, DO NOT get the black slave that comes from the cheap parts stores. Lucky to get a year out of it. Get the oem part that has the natural aluminum color and AP stamped on it. I found it at NAPA for the same price as the junk one. $75. $140 at dealer. Tick performance also has it.
What is this drill mod?
#68
It's basically when you drill a bigger hole in your Master Cylinder so more fluid flows to the slave and disengages the clutch. Essentially the cheap alternative to getting the Tick MC. Walk through here:
http://www.installuniversity.com/ins...r_cylinder.htm
