sqeaking slave cylinder??
My Clutch was replaced about 3000 miles ago along with the ram master and slave cylinder. now when the car is sitting at idle there is a sqealing /squeaking sound. It goes away when I push the clutch pedal in. I think it may be that slave but has anyone ever experienced anything like this?
Pilot bearing would be more likely if it goes away when the clutch pedal is down since when the pedal is down the trans input shaft stops turning in the pilot bearing, therefore stoping the squeak.
Gonna have to pull the clutch to get to it. Let me guess you didnt replace the pilot when swapping the clutch out?
Originally Posted by Goldstreak65
No I replaced the pilot bearing as well the one I took out was like a bronze bushing type bearing and the one I put back in was a needle bearing.
