It won't go...
Old 09-15-2007 | 02:59 AM
blkbird_WS-6's Avatar
Default It won't go...
I just put a new clutch package in my TA, and as I was putting the tranny back on the tranny will only go as far as to allow the front of the release bearing to touch the fingers on the pressure plate. I took it back out and tried again and still no luck. What am I missing here?
Old 09-15-2007 | 03:27 AM
My bad, I did some searching, I'll try tomorrow to see if any of the info I found helps.
Old 09-19-2007 | 09:51 PM
Still won't go!!! WTF??? I'm getting within an inch, inch and a half and that's it. I have done this before, and I'm doing nothing different than the last time. Any suggestions?
Old 09-19-2007 | 10:10 PM
02silvaZ's Avatar
are your input shaft splines lining up with the splines on the clutch disc?
Old 09-19-2007 | 10:17 PM
Yeah, it just hangs up afterward. It's not hitting on the dowel pins yet, it's not that close.
