ls7 clutch swap?
ls7 clutch swap?
will it swap directly into a 2001ss without any slave or clutch master cylinder changes? and how much better is it than a ls6 upgrade in terms of hp holding capabilities? im wanting to leave arounds 4-5000rpm at the track w/dr also is a aluminum fw worth it for hp gains?
current mods
175shot
lt
ex.
9in 4.10 gears
tuning done by myself hp tuners
80mm tb
.610 comp cam
stock clutch
current mods
175shot
lt
ex.
9in 4.10 gears
80mm tb
.610 comp cam
stock clutch
Its a direct bolt on. I recommend you get a remote bleeder.
Your going to need an LS2 Flywheel. For Drag racing a light weight fly is not always a good thing. PLus a little more weight on the rotating assembly will make drivability on street much easier.
how do you like it in yours? conelite? is it a better option than a ls6 scoggin dickey got the whole kit for 399.00 cant find a ls6 for that so fare. will it hard to hard launches at the track??
Check this thread on the aluminum flywheel and drag racing
I've posted this before but I'll post it here as well
FLYWHEEL WEIGHTS
Stock ls1 flywheel-24lbs
Slp billet ls1-16lbs
LS7-26.5 Lbs
Firdanza ls7-13lbs
CLUTCH & FLYWHEEL WEIGHT
Stock LS1 (2004 GTO) - 49lbs
Stock LS7 (2006 Z06) - 57lbs
Ls7 with aluminum-44lbs
There is no steel billet ls2 flywheel at this point that you can use with the ls7 so its stock steel or aluminum. Honestly with your 4.10 and sticky tires I think you will be fine with aluminum.
The ls6 is not an upgrade 01-02 m6 f-bodies recieved the ls6 clutch so it would be pointless to but that back in. The ls6 can barley handle lite bolt ons and the ls7 is cheaper than the ls6 so why even bother with the ls6.
FLYWHEEL WEIGHTS
LS7-26.5 Lbs
Firdanza ls7-13lbs
Originally Posted by van383
cool thanks... what the ls2 flywheel weight? i hate too do this upgrade and lose hp due to weight in the flywheel..sounds like ill be ordering the ls7 monday..ill ponder on the flywheel
The ls2 is the same weight as the ls7. There the exact same flywheel.
