Hays clutch vs LS6 clutch !!
I need some advice to get a best clutch for stock internal , daily drive and the best for street performance.
Hays clutch or LS6 clutch !!
IMO, for the setup you are describing (which is much like mine) you should be happy with the ZO6 unit. I got mine for a tick over $300. shipped. Part number 12570806 for a new flywheel, disc and pressure plate. Not too bad for a car that doesn't see much track use. As long as you don't dump it a 5K over and over, it'll more than likely hold ~ 380-400 RWHP.
WoW.. how is the clutch with you on street race?
and the pressure plate is same stock or upgrade it?
Can you give the website for your clutch..please
