t-56 gone!
Originally Posted by thesource
We all make mistakes , sooner or later you will realize yours and come back to the winning side . Until then , have fun in the rain fugger .......... ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
oh gee thanks that makes me feel tons better...lol and also thesource those metal flakes and threads are aluminum...what inside the trans is aluminum...its almost out i got one bolt left so gimme an hour to eat n go back out in the friggin cold @$$ wind
Originally Posted by 97badass
when its in neutral it makes a whining sound and it will go through all the gears but all of them sound like neutral except 4th... but if i busted the input shaft shouldnt i not have anything when its in 4th...btw kwiksilverz its freaking snowing and the winds blowing 20 mph if u want u can pull it out but im staying inside untill it quits!
Joe
Originally Posted by davered00ss
I just had mine out to replace the clutch. Now I need to do it all over to have the t56 rebuilt.
The top bell housing bolts are a bitch, but the torque arm was worse. ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
Joe
#32
im in idaho, it snowed for probably 5-10 mins and switched back into pouring rain and as for you the source. im glad your having nice weather and thats definatly news i wanted to hear about the aluminum but i will be done with it in about an hour...and the top bellhousing bolts???? u mean theres more that hold the trans to the bellhousing on top of the trans??? if so then i got more than one bolt
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#35
im in idaho, it snowed for probably 5-10 mins and switched back into pouring rain and as for you the source. im glad your having nice weather and thats definatly news i wanted to hear about the aluminum but i will be done with it in about an hour...and the top bellhousing bolts???? u mean theres more that hold the trans to the bellhousing on top of the trans??? if so then i got more than one bolt ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#36
Hell I doubt it will snow where I live at all . The last time it really snowed here was in early 1985 !!!
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
#39
I also reccomend using the quick disconect for the hydrolics rather than unbolting the slave to let it hang. Just easier.
#40
ok im back inside again to ask you guys a question or 2...ok the first is arent there 6 bolts that hold the trans to the bell housing? and if so what would keep it from sliding out?
