t-56 gone!
#42
Originally Posted by thesource
Unbolt the trans from the bellhousing . Not the bellhousing from the block .
#43
Might be hanging on the pilot bearing . I'd probably take a close look at the end of the input shaft for wear and replace the pilot bearing while you have it apart .
As for getting it apart , you might need to use a pry bar or large screw driver to pry between the front of the trans and the bellhousing to help it out but make sure you have a hold of the trans when you do this in case it just slips out really easy .
#44
its up on a jack, i dont think its very secure though so im just gonna stay out from under itand try the prying technique and if that dont work i will wait untill morning its starting to get dark here and i dont have a light to work with...
#45
ok its completely out and apart now the two very front gears are toast along with the bearings so i need a new cluster and input shaft and the bearings and while its a part im gonna put new synchros n your basic replace items. is there any upgrade parts i can put in there to make it stronger?
#46
Damn you are screwed ....... The cost of those two gears alone new are going to be damn close to what you can find a used one for .
Do the gears look like they are blued and layed over or do they look like shiny breaks where the teeth use to be ?
Basic list of parts you will need at the minimum :
LT1 input shaft
Cluster gear
complete bearing kit
Steel 3/4 fork
syncros through out the unit
fork inserts for 1/2 , 5/6 & reverse
Very possibly a 3/4 slider assembly if the gear got into the hub and did damage
LT1 input shaft
Cluster gear
Steel 3/4 fork
#47
LT1 input shaft
Cluster gear
Steel 3/4 fork
LT1 input shaft
Cluster gear
Steel 3/4 fork
#48
Is the other unit an LT1 ? If so and its not from a 93 model car , then you are good to go . The way you described the damage really sounds like the unit was run low on fluid . How much did you drain out ?
PM sent .......
PM sent .......
#50
ok how much does that transmission mechanic stuff in a can cost is it cheaper than rebuilding mine? or buying one from you and also do u take cores if they look like mine? no front 2 gears?
#55
Originally Posted by davered00ss
I meant the bolts to the bell housing. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Joe
