bolts that connect to crank
ok i just got my spec clutch and flywheel and they told me that it came with pressure plate and flywheel bolts but i would still need the ones for the crank (which is what i thought flywheel bolts were) and the flywheel bolts from arp are the 11mm ones
so am i good or should i wait to see what comes with my flywheel?!?
thanks guys
Jon
I'm not sayin they won't stretch, so on that note if you want the added strength get a set of ARP's.
