How to change a slave cylinder?
To swap the slave you have to pull the tranny because it slips over the input shaft.
For the master, just disconnect the pedal linkage and take off 2 bolts holding a U shaped bracket that's it. You may or may not need to remove the brake booster because it's right underneath it. It all depends on how much room you have to get to it. Or you can go from underneath, just depends what kind of headers you have.
