Hydraulic clutch tip.
Old Jun 7, 2003 | 03:26 PM
onfire's Avatar
Coal Mining Director
Default Hydraulic clutch tip.
My cartek clutch started to feel spongy. So I bled the slave and the pedal felt great again. However, the problem was the clutch hydraulic line laying on my header tube....boiling the fluid and making air pockets. Two tie wraps and that will never happen again. CHECK YOUR CLUTCH LINE IF YOU RUN LONGTUBES.
