Re-balance Flywheel?
Old Jun 7, 2003 | 03:57 PM
Gold Phoenix's Avatar
Default Re-balance Flywheel?
I have had my stock flywheel resurfaced for two replacements of clutch discs. I noticed a vibration at about 2000rpm. Is this cause because it needs to be re-balanced?
Old Jun 7, 2003 | 04:39 PM
trackbird's Avatar
Default Re: Re-balance Flywheel?
Surfacing...or at least correctly surfacing (meaning it was cut square, flat, and level....and preferably ground and not turned on a brake lathe) should not affect balance. You are removing an equal amount of material (that should be the same weight and density) across the entire surface. I'm sure that it could have an effect on balance....but I suspect the difference would be less than a few grams (and virtually unnoticeable). I doubt the flywheel surfacing caused your problem....just my thoughts.
Good luck!
