Ram 6130 Installed I..
Old Jun 9, 2003 | 05:13 PM
Unusual T/A's Avatar
Default Ram 6130 Installed I..
have to say I'm not to happy with it at all. I installed the 6130 along with the 402PP and mccleod adjustible master. I also bought a new 02 slave and throwout bearing along with a new pilot bearing. I also did the drill mod. The pedal pressure is insane, I have to basically stomp on it to push the pedal down(aka the leg press). If I knew it would be like this I would have kept my stocker. I only have about 50 miles on it so far and no chatter though. Those with this clutch is this normal? Will it ever get easier to push the pedal down? If so did you get used to it? This is my daily driver and I will have a cam soon, so I need something maybe more streetable. What are my other clutch options?
Old Jun 9, 2003 | 05:22 PM
Scalpel's Avatar
Default Re: Ram 6130 Installed I..
You'll get used to it. Besides, if you want to have a clutch that can handle all the power you can throw at it this is the one to get. If you went with a stock one and added some power it'd do nothing but slip.
Old Jun 9, 2003 | 07:43 PM
Jason99T/A's Avatar
I can shift faster than you.
I'm locking this one since you started another thread.
