trans doesn't want to go into reverse
Old 10-22-2007, 07:36 AM
krobinson123's Avatar
Default trans doesn't want to go into reverse
Yesterday after getting my car tuned I go in it to go for a drive. When I tried to put it in reverse it just would not let me move the shifter over far enough to go up into reverse. I'am able to get it to go over, but I have to force it using both hands. One person said that it probably is the spring in the hurst shifter. I have never had this problem before yesterday. The car is a 02 z28 m6. Any one have this problem before?
Old 10-22-2007, 01:42 PM
Galen's Avatar
I had the same problem...searched the forum and found a thread that pointed me in the right direction. My problem was a blown fuse under the hood. Seems like it was a sensor fuse, but I can't remember for sure. I tried a quick search for the thread, but couldn't find it. Hope this helps.
Galen
Edit: Here is the thread. https://ls1tech.com/forums/showthrea...t=#post7732435
Old 10-22-2007, 04:12 PM
99WS7's Avatar
reverse lockout solenoid could be your problem.
