Bellhousing & Flywheel PN's
Old 10-23-2007, 06:29 PM
donjazz's Avatar
Default Bellhousing & Flywheel PN's
Hi guys,
I'm doing a t56 to (2004) 4.8L bock setup in my Ls1 Rx7. I used to own two Fbody's so please don't hate on me to much. I do need some fbody expertise...
I need t56 Bellhousing and flywheel bolts so I searched the forums and found part numbers for bellhousing to block #22649772 but then I used that PN at GM direct and the search turns up as a $5.56 screw? Also, the guy working on my ride said he needs bellhousing to tranny bolts but the post with the parts list didn't say...so are they the same as the others?
I also need PM's for Flywheel to crank and Pressure plate to Flywheel...
I found these numbers on the post. flywheel bolts 12553332 and Pressure Plate 12561465 but the post didn't say what they were connecting to..so does that matter...sorry for my ignorance
Thanx in advance
Old 10-24-2007, 07:27 AM
WFOWS6_IL's Avatar
Not for sure on part numbers, but I used M10x45mm grade 8 allen headed bolts for bell to block and trans to bell. The thread pitch was 1.50.
Not for sure on flywheel. If you go to the dealer they might have them in stock.
Old 10-24-2007, 03:57 PM
donjazz's Avatar
Thanx, I'll give them a try
Old 10-24-2007, 04:22 PM
ls1 joe's Avatar
If you need the bolts call me. I have them in stock $2.00 each.
Amber
Quick Reply: Bellhousing & Flywheel PN's
