Help with Spec Stage 1!!!
I just realized the throw out bearing that comes with the clutch is different then the stock one. Do you HAVE to use the Spec t/o bearing that comes with the kit? And do you still need to use the spacer?
P.S. Slave cylinder and master cylinder are both new. Thanks
