What is wrong with my clutch
Old Jun 18, 2003 | 10:33 AM
WHITETIGER's Avatar
Default What is wrong with my clutch
Okay last September I purchased SLP high performance clutch. Lately I have noticed epecially out at the track or on hard runs my cluth pedal will stick close to the floor and not come up with out me pumping it a few times or waiting for a second. Plus when it does this I can barely get it in the next gear if it even goes. Does anyone have any ideaas what this might be?
Old Jun 18, 2003 | 10:57 PM
WHITETIGER's Avatar
Default Re: What is wrong with my clutch
TTT
Old Jun 18, 2003 | 11:31 PM
rnr27band1's Avatar
Try bleeding the clutch and slave, also do you have an adjustabel master? if so you probly need to adjust the rod out so the peddle is up higher, if you dont have an adjustable master you might need to get one, i suggest the Futral motor sports one.
Old Jun 24, 2003 | 12:13 PM
smokinHawk's Avatar
pressure plate to week
get a better clutch
happened to me i went throw all the hydrolics and such, but no luck
thinking of a cartek
