Resurfaced flywheel (.035") + SPEC Stg3
Old 01-07-2003 | 05:20 PM
xaon's Avatar
Default Resurfaced flywheel (.035") + SPEC Stg3
I took my flywheel down today and had the machine shop resurface my original flywheel. He had to take about .035" off of it. I also ordered my Gen2 SPEC Stage 3 Carbon clutch/PP today without flywheel. I will be running stock '01 hydraulics with 15k miles on them. I am putting down 375-390rwhp N/A and have a 75 shot on the car, and eventually a 150shot after i upgrade the fuel system a bit.
Will I be fine or should I pick up another new flywheel for this?
TIA.
Old 01-07-2003 | 06:37 PM
Sears's Avatar
!Dial-up Director
Default Re: Resurfaced flywheel (.035") + SPEC Stg3
I would contact SPEC about this. They do supply a shim with some of their clutches. My machine shop takes .015 for a resurface and I run no shim, SPEC stage 4, new slave, mcleoad adjustable master.
Justin
Old 01-07-2003 | 08:04 PM
JurisAg02's Avatar
Justin I heard the Stage 4 was weaker than a Stage 3 SPEC, is that true or just a rumor? I wanted a stage 4 but people tell me it isnt streetable...what experience do you have with it? Does it leave any play at all to leave smoothly from a red light for example?How much power are they rated at? I was thinking of going with a ceramic one for durability. thanks
Old 01-08-2003 | 11:57 AM
xaon's Avatar
here's what I got back from Star. Guess i'll be picking up a new flywheel.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">The maximum recommended turn on an LS1 flywheel is .020 . Anything past that number and you're asking for warpage issues, imbalance and lack of hydraulic throw, which will not allow the clutch to release properly. I wouldn't chance it- it would cost you labor all over again.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old 01-08-2003 | 03:42 PM
Sears's Avatar
!Dial-up Director
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by PhatT/A:
<strong> Justin I heard the Stage 4 was weaker than a Stage 3 SPEC, is that true or just a rumor? I wanted a stage 4 but people tell me it isnt streetable...what experience do you have with it? Does it leave any play at all to leave smoothly from a red light for example?How much power are they rated at? I was thinking of going with a ceramic one for durability. thanks </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">IDK where you got that info but as far as I know that is not true. I like the ceramic disk so far, it is much easier to drive in traffic then my iron disk was. The pedal pressure is a little stiffer then stock but not much. I like it a lot, then engaugement is linear and predictable. A local guy, "95 Formula", has put his SPEC stage 4 through hell and back in his 400+rwhp, 1.5 60' cutting formula and his clutch has held up fine.
It is streetable in my opinion but I have a high tolerance for that kind of stuff. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Justin
Old 01-08-2003 | 07:11 PM
MIGHTYMOUSE's Avatar
definitely stronger than the 3, especially if you go for the no springs disk <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> and actually, i think it is MORE streetable than my old stage 3.. less chatter.
