LS7 Clutch
Old Nov 14, 2007 | 04:45 PM
95_transam_lt1's Avatar
Default LS7 Clutch
Im looking to put an LS7 clutch in my ls1, but didnt know if i could just bolt up a gm stock ls7 clutch. I was going to do both the flywheel and clutch, ive heard about this before but wasnt sure if it was a kit from an aftermarket company or what.
Pleas help
Old Nov 14, 2007 | 04:56 PM
LS1GameOVR's Avatar
got mine from Scoggin Dickey, they are a sponsor here, great prices, if you get a ls7 clutch kit from scoggin it comes with everything you need, however might aswell get a new roller pilot bearing, slave cylinder also, i installed mine, and i absolutely love it, takes like 300-500 miles to break in, but shes a beauty
Old Nov 14, 2007 | 04:57 PM
LS1GameOVR's Avatar
the ls7 is a bolt right up mod, i mean its not easy.. however you do need an ls2 flywheel, the ls7 will not work, the ls2 comes in the kit from sdpc
Old Nov 14, 2007 | 06:35 PM
00Hawk437's Avatar
Installed an LS7 clutch not too long ago.....and went along with a slightly used LS2 flywheel. Bolted on and lovin it!
Old Nov 15, 2007 | 01:02 AM
mighty-z28's Avatar
How much is that kit ???
Old Nov 15, 2007 | 04:58 AM
rx_treme's Avatar
any idea how much torque that clutch can hold?
Old Nov 15, 2007 | 05:33 AM
00T\A's Avatar
Got about 200 miles on mine and i love it.
Old Nov 15, 2007 | 01:05 PM
Hugger Z's Avatar
Mine is surviving with 513 rwtq. Over 4,000 miles on the set-up now and the clutch was on the car since springtime with no slip issues or anything. Drives great. Still DD'ing it until the weather turns nasty. When the salt hits the road the car goes away.
And yes you NEED the LS2 flywheel. The LS1 flywheel has a smaller contact area and will not work with the LS7 clutch. The LS2/LS7 has a larger contact area hence the higher power holding ability.
Old Nov 15, 2007 | 05:42 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The LS2 and LS7 flywheels are the same
Old Nov 19, 2007 | 10:16 AM
mighty-z28's Avatar
LS7 Clutch Kit $399 FREE SHIPPING !!!
This is the best price you will find !!! and FREE SHIPPING !!!
Only 2 Left so hurry up !!!
You can use this with no modification in any Camaro/Firebird with an LS1.
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=004
Old Nov 19, 2007 | 10:22 AM
connexion2005's Avatar
+1 Same part and part number.
Old Nov 19, 2007 | 07:04 PM
defenestrate's Avatar
just installed this clutch as well, when you first install it it engages very low...but it feels great.
