problem with slave
Old Nov 17, 2007 | 04:41 PM
thecamarokid's Avatar
Default problem with slave
ok so i was doing the drill mod and everything was going smoothly until i went to bleed the system. The car is a 99 trans am. I was loosening the bleeder and it felt like the bolt broke. Now i can not feel the hex shaped bolt and im guessing it is lost in the bell housing? and when i was pumping the clutch to see if i lost all presure i look under the car and see alot of fluid leaking out of the bell housing. did i really mess up and am i now going to have to remove the tranny to get to the slave?
