Cartek Clutch Fluid Replacement?
Old 01-10-2003 | 09:33 AM
CB99SS's Avatar
Default Cartek Clutch Fluid Replacement?
What's the best way to replace the clutch fluid? I have the cartek setup and after a hard run the clutch gets soft. I've spoke to cartek and they sugested I replace the fluid with syntetic brake fluid. So I'm wanting to see what's the best and easiest way to change the fluid is.
Thanks
