Clutch line connecting two halves
I am in the process of converting my lt1 to ls1. the ls1 clutch line wont seal up to my lt1 master, the fittings are different thickness, is there a way i can buy some "an" fittings to connect half lt1 side hose to half ls1 side hose? i believe its -3an braided factory hose
i tried to heat up and remove the ls1 fitting and replace it with my removed lt1 fitting but the ls1 side got messed up
heres a pic of the lt1 fitting to the master
LS1 uses -4 braided hose.
Any of the suitable -4 hose ends will work with it. I joined a bit onto my car when I fitted the LS1 to it. I was using a Girling MC that was already on my car. Although its a Wilwood on it now.
