can't decide
I am actaully over the rating for the SPEC 3 though, so I am expecting it to go out sooner than if I had less RWHP. I plan on doing a 3+ when mine goes.
Long story short, you should be fine with just the SPEC stage 3. If you want the added insurance, go with the 3+. Either way, SPEC is probably the cheepest clutch that will hold up to the HP you are having, and last.
