Drill mod on M6
Re: Drill mod on M6
The line that connects the tranny to the master cylinder needs to be opened up a bit (1/8 I think, don't quote me on that). This is done easiest on a clutch swap and upgrading the hydraulics. I believe the end that goes into the tranny has the hole that will need the enlargement. Run some fluid and/or compressed air through the tube to remove trash then rebleed (PITA) and you're done. Hope this helps.
Jason
Jason
Re: Drill mod on M6
Thanks a lot bro. I was under the impression I had to drill the quick release not the disconnect end. I would have messed things up.
