What do i need?
And also, i am probably going to have this professionally installed so what is EVERYTHING that i will need to give him?
But as for parts.
Clutch
Pressure Plate
Flywheel
NEW GM bolts
Slave/Master cyl updated to 2001+ specs
Throw out bearing
Pilot bearing
Clutch fluid
Rtv for the shifter
Loctitie for flywheel bolts.
Something to bleed the fluid, the professional shop should have this, or at least their method.
I found the clutch, LS7, comes with a pressure plate and flywheel
Does anyone have a link where i can buy all of this stuff
Oh, and ^^^ what does that mean
