one for the LS7 clutch.
Old Feb 18, 2008 | 12:17 PM
SladeX's Avatar
I kept my 98 master, but changed it 6 months later. The revised 01-02 masters push more fluid. Also do the drill mod and protect and insulate the hydraulic line from heat. I have mine covered with coolant hose, a spark plug fire boot and some aluminum tape. It's stayed fairly clean since being protected like that.
Old Feb 19, 2008 | 11:00 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Originally Posted by BlackIce2123
So does this sounds right? I'm about to get my trans rebuilt and while its down I'm getting the LS7 cluch kit, the LS1 Slave, LS2/LS7 pilot bearing and then I should be good to go or should I go ahead and replace the master while were at it?
A regular LS1 pilot bearing will be fine
