one for the LS7 clutch.
Old Dec 10, 2007 | 03:22 PM
RealLiveMD's Avatar
Default one for the LS7 clutch.
Just finished my 650 mile breakin for my t56 rebuilt trans and ls7 clutch. I saw a 454 chevy and had to hunt him down. After 1st gear, I pulled 2nd and the car jumped sideways. It never did this with the ls6 that wouldn't let me go into 3rd. Feels stock, but grabs hard. I like it. Now I just have to get use to it. I was going to get 3.90's before Christmas but I'm not sure I need them now.
Old Dec 10, 2007 | 08:46 PM
soontobeLS1's Avatar
did this fix your "soft clutch pedal" thing where it keeps you outta gears at high rpm's???
Old Dec 10, 2007 | 11:19 PM
RealLiveMD's Avatar
so far it seems like it did. And I know exactly what you're talking about. Actually, it appears that the drill mod had fixed the problem initially but then it recurred.
Old Dec 11, 2007 | 12:44 AM
jmdale1984's Avatar
Yeah... I love these clutches... I'm on my second now. They really do feel stock, yet, grab like a SOB! Fixed my soft pedal, and I've yet to do the drill mod.
Old Dec 11, 2007 | 11:39 AM
That sounds good, I did the drill mod, didnt make a difference. So, I figure it must be my stock clutch not holding power as well as older hydraulics. Debating myself between the Tex 0z700 and the ls7....it will be nice to actually be able to drive the car the way it is supposed to be driven.
Old Dec 12, 2007 | 11:31 AM
EndlessSummer85's Avatar
When you did the clutch install did you reuse the stock hydraulics or did you get new slave cylinder??? Was thinking when I do mine to just do the drill mod... Was gonna get the clutch/flywheel, new flywheel bolts, pilot bearing, and alignment tool. Should that be good enough??? Or should I buy the slave too, I know it's only another $130 or so, but with everything else and the ATF it's gonna be around $500 all ready.
Old Dec 12, 2007 | 11:38 AM
RareBreed0295's Avatar
Jmdale, how long did your first ls7 clutch last?
Old Jan 21, 2008 | 12:53 PM
NIKDSC5's Avatar
whats the drill mod?
Old Jan 21, 2008 | 01:42 PM
LS1C5Vette's Avatar
Check here: http://www.installuniversity.com/ins...r_cylinder.htm
Old Jan 22, 2008 | 10:02 AM
Midnight02's Avatar
That is precisely what I was hoping to hear! My car is in the shop right now getting a LS7 clutch installed. I opted not to replace the master cylinder (and do the drill mod)....I'd like to see if the clutch fixes my sticking pedal issues first. If it doesn't, at least the problem should then be isolated to the MC.
Old Jan 22, 2008 | 12:10 PM
Shredder_Z28's Avatar
yea you should deffinetly go ahead and replace the slave with the tranny already dropped for the clutch. I made the mistake of not doing that when i did my first clutch install and roughly 1k after breaking it in the slave went south so i had to drop the trans again..Most quality shops won't even install a new clutch without a new slave just for cheap insurance. The LS7 clutch is a great for the street!!!
Old Jan 22, 2008 | 02:08 PM
NIKDSC5's Avatar
Originally Posted by LS1C5Vette
ahhhhhh... got to love good old engineers hard at work! but thanks for sure thats great to know right about the time I change my clutch. I dont plan on changing the master cyl though so will mine still be fully adjustable? or is that just a perk of the mcleod master cyl? the drill mod should just help clutch engage ment and such correct even on a stock master cyl?
Old Jan 23, 2008 | 01:38 PM
WS6_00's Avatar
RealLiveMD what else did u put in or upgrade? ls7 clutch,...... new master cylinder? what kind?
I ask because my transmission is really hard to get into gears at high rpms.. please spill ur info lol
Old Jan 23, 2008 | 01:48 PM
camaroguy26's Avatar
good to hear this!! I have a new LS7 clutch package with all new hydraulics and a T56 rebuild kit waiting for me at home
Old Jan 24, 2008 | 10:55 AM
Im running a new stock master cylinder. I had a Mcleod adjustable master but it went out on me before i put in the LS7. Ive heard the Mcleods can prematurely wear out a clutch. Ron @ Vengeance told me this when my Spec 3 started slipping extremely bad after 8k on it and no track time. In my case the pressure plate took a crap on me but i know i haven't had any issues with shifting or grinding at any rpms since i put in the LS7 clutch and new hydrallics
Old Jan 24, 2008 | 11:20 AM
WS6_00's Avatar
thats good to know shredder, I was going to get a Mcleod adj master. I'll stick with a new stock one and a ls7 clutch. a 01,02 master is the best right? I hope this helps my shifting, people probably think I can't shift lol
Old Jan 24, 2008 | 02:13 PM
I've heard this same thing, there's a few threads on this discussion about the Mcleod MC. There is however another company I forget the name, but they have the GM Master Cylinder and modified it to make it adjustable, just like the mod you can do yourself.
Old Jan 24, 2008 | 02:26 PM
yes the 01,02s are the best. I'm not sure if they even make the older version anymore just like the slave cylinder. New hydrallics should help your shifting alot.
Old Jan 24, 2008 | 03:18 PM
Black FormulaLs1's Avatar
not sure myself i would go with either the textralia or the ls7 myself but my spec2 combo has held up fairly well...unfortunately my last 2 ten bolt assemblys havent..
Old Feb 18, 2008 | 11:40 AM
BlackIce2123's Avatar
So does this sounds right? I'm about to get my trans rebuilt and while its down I'm getting the LS7 cluch kit, the LS1 Slave, LS2/LS7 pilot bearing and then I should be good to go or should I go ahead and replace the master while were at it?
