Short Stick Question
Old Dec 10, 2007 | 09:37 PM
rudeLT1's Avatar
Default Short Stick Question
OK so i have done some research and have narrowed it down to either the UMI or Lou's Short Stick. Both i like due to the slight bend toward the driver, my question is- Is Lou's worth the money over the UMI? They both seem the same, UMI is cheaper so is there a quality or performance difference??? I have an aftermarket hurst and want pretty much the shortest stick i can get on there without any problems. Let me guys know what you think.
thanks a ton!
ryan
EDIT: I just thought I would add the prices. LSS-$47 UMI-$26
Old Dec 10, 2007 | 09:41 PM
chuckyt1's Avatar
I have the UMI stick and am very happy with it. I haven't used a Lou's tho so I can't compare. UMI has great quality on all the parts I've gotten from them...
Old Dec 11, 2007 | 04:22 PM
rudeLT1's Avatar
anyone else have any experience with either of these...?
Old Dec 11, 2007 | 04:51 PM
LS1W66's Avatar
I have a Lou's short stick on my Hurst Billet and I love it.
Old Dec 11, 2007 | 05:33 PM
rudeLT1's Avatar
anybody have pics of either in their car?
Old Dec 11, 2007 | 07:54 PM
rudeLT1's Avatar
Ive been looking around and found Lou's page.......the LSS on an aftermarket hurst looks like it has an insane amount of angle to it, id like some angle but that looks like a ton.
Anybody have LSS on an aftermarket hurst? Hows it feel when driving?
Old Dec 11, 2007 | 08:44 PM
geeteego's Avatar
I have an LSS on my GMM-equipped GTO. I absolutely love it.
Old Dec 12, 2007 | 08:25 AM
teke184's Avatar
i've had my LSS on 2 cars...both equipped with the factory Hurst shift unit.
on my 96Z the shift **** came very close to console when in 2/4/6th gears
i later installed an MBA shift ****, which is designed to shorten your shift stick even more (hole drilled deeper in). with that ****, and the LSS there was actually contact on the console. just barely, not enough to affect function or to break the console, or affect shifting. the stock **** worked fine, as would the Hurst **** (factory).
installed the same shifter on my 99z along with the MBA ****...the redesigned console has no problems accomodating the short stick. there is plenty of room.
i measured the throw on the base model stock shifter and stick...from 1st to 2nd the **** moved about 8"
with the hurst shifter (factory) and the LSS, the **** only moved 3.5" from 1st to 2nd.
HUGE improvement in travel...and in firmness!!!
these pics are of my 99z...LSS, hurst shifter, MBA ****....trans in neutral
another view...stock lenght (with hurst shifter..in neutral)
LSS (w/ hurst in neutral)
Old Dec 12, 2007 | 03:08 PM
BriancWS6's Avatar
UMI and I love it! So far two of my buddies got rid of their shifter setups for one like mine, they liked it THAT much!
Old Dec 12, 2007 | 10:30 PM
93blcZ28's Avatar
planning on getting a UMI heard good things bout them
Old Dec 13, 2007 | 08:02 PM
mypoorLS1's Avatar
The Lou's bends forward or back. Not toward the driver.
