How much does it cost to replace a syncro?
Anyways, anyone have this done by a shop, or a dealer before? I just want to get some kind of ball park on how much this is going to cost me.
Hope it gives you some insite to cost.
Thanks,
Amber
Before I get ahead of myself, does it sound like the syncro is my issue here? Very specifically, if I am driving the car hard through the gears, and I try to go into 5th from the top of 4th, a lot of times it won't go in at all. If I try to downshift from 6th to 5th, or even upshift from 3rd to 5th sometimes it won't go in no matter how hard I try. If I am driving the car under regular driving conditions and I shift from 4th to 5th it grinds. However if I pull the shifter out of 4th with the clutch down, and wait a second or two, and then shift it into 5th, it goes in as smooth as butter with no sounds. Does this sound like a syncro? Or do I have other issues at work here?
Thanks,
Amber
Amber
5/6 Slider- $95
Carbon Blocker Rings- $169
Bearings- $159
Everything else will be at your discretion and what you want to spend the money on. The other things we normally suggest replacing but make the cost go up are:
1/2 Slider- $115
3/4 Slider- $115
Steel 3/4 For- $39
Billet 3/4 Keys- $75
Bronze 1-2 Fork Pads- $30
Bronze 3-4 Fork Pads- $30
Now as far as the gear goes that would be if it is damaged. The gear is $95 and depending on how long it has been since the problem started the gear might be fine. In most cases it is but there are those out there that can't be saved.
Amber
Amber
I just fixed a reverse problem in an f-body t56 today. Our labor to pull the transmission from the car is $200. I charged 1 hour labor to remove the tailhousing and repair the reverse components ($68). His total bill with a new slider and blocker labor and all was less than $400.
Jonathan, what would be the turnaround time in fixing my tranny? Would it be something that could be done in a buisness day? Or are we talking much longer?
5/6 Slider- $95
Bearings- $159
1/2 Slider- $115
3/4 Slider- $115
Steel 3/4 For- $39
Amber
