Issue- T56 Magnum bottoms out on 5.3 crank with Quicktime bellhousing!
I have an '08 alum 5.3 engine with McLeod street twin clutch (just rebuilt), Quicktime RM-8020 bellhousing, and T56 Magnum transmission I'm trying to put into my '69 Chevelle turbo project.
I'm running a 2001 Camaro small pilot bearing and I can physically see the input shaft snout leaving a light circle in the back of the crankshaft casting (deeper past the pilot bearing). There is some paint transfer from the crank to the input shaft so I know it is contacting there.
Here is the bearing I have:
http://www.swaptastic.net/images/pilot_bearing_7.JPG
I am running the steel .115" thick spacer/plate that comes with the Quicktime bellhousing.
I even removed my slave cylinder to make sure there was no binding going on there and same problem.
WTF is going on here? Everyone I talk to says this should simply be a bolt together. Quicktime, Tremec distributor, McLeod
What am I missing?
What am I missing?
Have you measured the crank plug depth on the 5.3? The late 5.3s never had manual transmissions behind them that I am aware of so the crank plug might not have been driven as deep as the early ones. I dont see this being a problem as long as you have the correct measurement from the flywheel mounting surface of the crankshaft and the slave cylinder mounting surface of the transmission. The Quicktime bellhousings have been known to be slightly shorter than the stock bellhousing. So this maybe contribute to your issue. If the trans mounts up flush with the bellhousing and is only putting a slight witness mark on the plug, file off a small amount of the input pilot snout and let it ride.
my stock t56 input shaft is roughly 6 1/2 inches and my 8020 bellhousing is 5 5/8 inches roughly, motor plate is 1/8'' roughly. You can check that to see if there is a large difference in one of those measurements. Jeremy is probably right about the crank plug being out further. He can help you 100x better than i can.
Do not drill into the crank, there is a freeze plug in the end of the crank, that plugs the oil galley that runs through the crank.
Correct..... I cut 1/8" off of the input shaft tip and then put a bevel back on it.. No more issues.
I'm guessing it is related to the Quicktime bellhousing.... or maybe as others have suggested the truck crankshaft isn't machined deep enough as they never had a manual transmission in the later years.....
